Hi Guys
After some opinions.
Looked at a consumer unit today installed cu in 2008 under the 16th edition ie split load CU usual configuration cooker, immersion & lights on non RCD & shower & sockets on 30mA RCD side. The reason for the replacement cu in 2008 was to update the existing system
The customer recently had an electrical test & inspection carried out by the firm who installed the cu in 2008.
This cu was replaced just prior to the dual RCD requirement.
On their test they picked up that some of the circuits have no 30mA RCD ie circuits 1-5 on the non RCD side & have coded this as a code 2.
As you can imagine the customer is spitting teeth that a CU fitted in 2008 is now deemed to be potentially dangerous
Any thoughts?
Any thoughts?
