- Reaction score
- 6,969
Screws......as in brass 4mm or 2BA, as used to be used.Screws ? Or did you mean bolts
I hope you're not talking roofers
Discuss AM2- Clipping cables to tray with P clips? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
I've never seen a 4mm brass bolt - all have been screws. Bolts have an unthreaded section part way along the shaft, starting from the head.It is bit daft if you have no screws to help fit them all.
The only brass bolts I've commonly come across are supplied with clamps for earth rods.
That's a type of screw, not a bolt, as the first line of the description alludes to.M4 x 30mm Hex Bolt Full Thread in solid Brass - DIN 933 - Westfield Fasteners Ltd
M4 x 30mm Hex Bolt Full Thread in solid Brass - DIN 933. Also know as a Set Screw or simply a Bolt. Purchase in box or sachet quantity | Next day Delivery.www.westfieldfasteners.co.uk
What’s wrong with 6mm brass nuts and bolts for banjos?
For me, a bolt doesn’t have a screw driver head. It’s the way you interpret, same as umpteen other items.
OK, I’ll bolt off.Don't you go spoiling a potential 3 day argument
Its actually listed as a boltThat's a type of screw, not a bolt, as the first line of the description alludes to.
I always used the definition that a bolt was only part-threaded, while a machine screw was fully threaded.A correctly specified bolt used to join two accurately machined components together will allow minimal lateral movement. Substitute a screw, lateral movement can occur and the stresses in the fixing will increase, sometimes to the point of failure.
Hex bolt Full Thread is an oxymoron.
Wrong side of the bed this mornin' ?
Blimey! Still at it.No, I just hate seeing trainees put down for the sake of making someone else feel big and clever
Reply to AM2- Clipping cables to tray with P clips? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
