- Reaction score
- 2,109
After or before your installHell, I can go into any farm cottage around here and see similar, if not worse.
Hey… I resemble that remark!After or before your install
Staring through a ladies window in the middle of the night will cause you to go blind
I thought that’s what happens if you couldn’t swallow a ------ pill properly and it gets stuck in your throat.Reminds me of an old Mike Harding line where he says he woke with a stiff neck after sleeping near an open French widow
It would if you were blind from looking through ladies windowsmakes no sense.
It does. Any sign of air vents that might be blocked?Looks a bit damp down there.
I've seen under-floor spaces that are tidal - literally, water level went up and down with the tideLooks a bit damp down there.
The only case for true rising damp.I've seen under-floor spaces that are tidal - literally, water level went up and down with the tide
Well thats one way to avoid random tripping HA HA!
What the actual f***!!!Good job someone went to the effort of making the live cable end safe.
However it would have been easier to just unplug it from the end of the block...
Someone experimenting...........Good job someone went to the effort of making the live cable end safe.
They will all be just to short to reach the lugs on the back box !Finally, I've won!
You noticed that too?They will all be just to short to reach the lugs on the back box !
Thats a bit unfair.... these are the gentlemen that invented the inflatable hot-tubIt seems the Darwin principle has failed.
What will happen if the adapter sinks ?
At a minimum , but anything else ?Cold food
