Search the forum,
Discuss Finally! No more faffing about with Sleeve! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dustydazzler
Supporter
View attachment EarthSure - No More Sleeving 👀.mp4
Edit by Admin: just testing something. I added that video directly to the post by clicking the three dots and finding the insert a video button. Ideally, we need pinch them and host them ourselves. They can report the video/post.
The place would become one big ad to meet the cost of hosting.
We have space and bandwidth. We had to, to out pace ddos attacks a few years back. Then we would just have a couple of ads on that kinda page. As you're not scrolling it's just whats in view on first visit.
I'll dig around see if I can find some that aren't part of somebody's yt income like.
It was what I chose the massive super fast ssd's on a octocore chip for in the first place. It just never really got used that way.
Can populate the area with YT embedded videos and then they get their income, its on a page that we have an ad on, and it isn't part of our space then.
Food for thought 🤔
Loads and loads more plastic on 1000's and 1000's of metres of cable which is not even needed! Awful.
...at least it will stop the DIy daves from just twisting all the bare earths together under one pieve of sheeve
It wasn't DIY Daves who did it on occasions I find twisted earths in a single piece of sleeve. Poor Dave gets blamed for all the carp work turned out by time served electricians 😁
Not a problem for me as I am down to my last few metres of G/Y sleeve. won't be buying another hank. I will be converting over to earthsure cable once I run out of my current T&E
Dusty, try and think a bit beyond the few minutes it will save on a consumer unit change compared to the impact on the environment.
Basically 5 minutes of time saved for a human being = 1kg of plastic (just pulling a figure out of thin air to illustrate the point)
It just doesn't make sense. Money is important, time saving is important, working more efficiently is important, a comfortable life is important, but it all needs to be weighed against the impact it causes. In this case there is a massive over balance between time saved and impact on the environment.
On average 80metres of extra plastic on a new ring when all you need to about 1m (sockets and CU).
10cm of plastic surrounding 1.5mm earth weighs (approx) 1g
therefore 79m = 79g wasted
On average lets say 250m cable used with a new build (1mm, 2.5mm, 6mm).
Roughly 250g wasted plastic.
200,000 new homes being built every year = 50,000kg of wasted plastic, just on new builds. 50 tonnes of crappy plastic to save a few minutes of popping a small piece of plastic over a few cm's of bare copper.
But if installed properly a new circuit in brand new pvc pvc cable 'should' last 100 years and more...
So I don't really buy into the 'wasted' pvc argument. I throw away loads off off cuts of sheeve every week that I either cut too short or pulled off a bit of old cable. I rarely throw away cable unless its a very short piece or very end of s drum
What about gripping the bare cpc with pliers and pulling it as a way of stripping t&e.
I don’t think the insulation on the new stuff will cope well.
(Yes. I know. Tongue is most firmly in cheek)
I've just thought of another downside to CPC sleeving.
I'm sat here, having a day off. My conservatory lights have been left on. I want a switch right by me to switch them off. the switch is miles away. There is however a PL and N coming from the switch all the way to a point (a pull switch light) right where i would like the new switch. Get rid of the light and I've got a PL and SL, just need a Link for the commons, but i haven't got one, or have I. You can see where I'm going now.
Instantly my brain disregards the idea because it would be completely wrong and unsafe to use a bare conductor and make it live throughout it's run. If it was completely sleeved though, that does actually make it safe to use as a live conductor, just from the point of view that it is covered. Of course I wouldn't do it as the cable and class 1 item wouldn't be earthed, but it did make me think twice. I think a DIY'er is now far more likely to use it as a live conductor. It'll be interesting to read the forum threads in 10 years (when I may be retired) and have a little smirk at the Dave's post 'oh my god, I can't believe what I've seen today'. Mike replies 'Yeah, that's common practise with DIYer's these days'.
PS.. We just need to see if I put my money where my mouth is now. Saving 20 minutes on a CU change sounds nice😄 (and think how neat you could get it!!)
Determined not to buy it though... at present!
Reply to Finally! No more faffing about with Sleeve! in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Eh up :) I've done some new PDF forms for BS7671 18th Edition Amendment 2 2022 (the Big Brown Book), based on the IET model forms. You can fill...
12K
Merry Christmas from ElectriciansForums.net What a weird year we’ve had! We will need to keep our wits about us during these next couple of...
5K
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
1. Images and videos are screwed up, I'm fixing that today. Fingers crossed. 2. Email for the forum is changing to something @...
