Search the forum,
Discuss TC-ER-JP, cable used for minisplit system -- should it be in conduit outside ? in the DIY Electrical Advice area at ElectriciansForums.net
ekubec
Hi, folks.'
I have a carrier 38MGRQ48E '5 zone' mini split system with 4 'heads'/evaporators installed, and one 'channel' still open. Had it installed about 6 years ago.
At the time the tech said "You really should install the fifth one in your bedroom."
I didn't listen to him and now i regret my life choices
So I have called the same company to install the fifth one. They are almost done--missing a ferrite beaded pigtail for the 5th 'circuit' but I am concerned over the wiring. The other 4 are in flexible conduit. Like every other AC high voltage conductor I have outside, they are appropriately shielded. This one they have have used southwire 14guage TC-ER-JP (which I have learned stands for Tray Cable-Exposed Run - Joist Pull) this rated for direct burial and is 'sunlight resistant.'
It is zip-tied to existing flexible conduit, and exposed outside where it goes into the condenser.
Is this legit?
thanks for the opinion.
Reply to TC-ER-JP, cable used for minisplit system -- should it be in conduit outside ? in the DIY Electrical Advice area at ElectriciansForums.net
I have a 20mm steel conduit drop to an accessory box buried in the wall. It was previously used for lighting cables and had 2 x 1.5 t+e and 1 x...
hello guys I have a lighting install at high level outside a house. I don’t need additional mechanical protection and would like to use a good...
6K
M
I recently purchased my first house and have decided to re-instate the electrical supply out to the shed. I’m a maintenance technician offshore so...
22K
spary
G
Hi all, I'm an ELV consultant (mostly sound and video systems for hotels, theatres, schools, etc. all commercial projects and mostly new...
Hi, I'm currently on a level 2 C&G course at college with a bit of experience. I have to install a socket outside in the shed in my own house...
6K
