Discuss The "Pinch method of stripping twin and earth cable" in the UK Electrical Forum area at ElectriciansForums.net
Like to see them do it with LSF.I think the farmers in our French village still use their teeth.
Oh, by the way, what are these strippers like with LSF T+E?
As it was put to me; the reason we score and strip is because we are craftsmen not just an electrician. Such precision is a way of thinking that should permeate all the work we do.
But you just have, commented that isI wanted to comment, but can't be bothered.
Cheap un talked cables, cheap job bad joPersonally, I think anyone who uses a CPC as a ripcord is just a butcher. I've been taught to do it in the past - but it really isn't what it was designed for.
I have a cheaper version of those CK strippers and it's my main tool for the job. For getting close to the box entry, just pull in sime if the slack, strip, push it back. What do you mean, you can't do that when the cable is bedded in plaster - what sort of bodger doesn't take the conduit into the box
They are great for small sizes of T&E, but IME 2.5 is pushing it. 1mm is a doddle.
I also have a different Jokari tool for cutting into the sheath on round cable - twirl it once around for a clean circumferential cut and in one movement pull it along for a longitudinal cut - then peel back and pull off the sheath.
For larger T&E I use a knife - using a technique designed to avoid injury.
And never underestimate the utility of shear type cutters !
Of course, only skilled use of a knife is any good where the cable manufacturer "forgot" the talc and the sheath is welded to the cores
I'm out of this, good some may sayPersonally, I think anyone who uses a CPC as a ripcord is just a butcher. I've been taught to do it in the past - but it really isn't what it was designed for.
I've had it with cable from "proper" suppliers, not just cheap stuff. Sometimes the talcing isnt right and there's no way to see it until a piece is taken off for sample testing.Cheap un talked cables, cheap job bad jo
I regularly do 10-20 DSOs in dado I can, and do, strip and prep the lot in minutes, its a no brainer.
years ago i was on a new build student accomodation block. cables were all T/E on tray above suspended ceiling in corridors, then into dado in the rooms.Why are you putting T&E in dado trunking?
Done that method as wellyears ago i was on a new build student accomodation block. cables were all T/E on tray above suspended ceiling in corridors, then into dado in the rooms.
It’s a bit of twin and earth ffs
Reply to The "Pinch method of stripping twin and earth cable" in the UK Electrical Forum area at ElectriciansForums.net
