Still going guys:
http://www.bbc.co.uk/news/uk-england-london-32157618
There have been surges all over central London, one knocked the till out in nandos when I was getting my tea last night, I was livid!
The same as LV networks, via earth electrodes....
TT for MV? I mean the neutral point of the supply transformer. A high resistance or Peterson earthed neutral point will drastically limit fault current greatly reducing the incident energy at a fault. Solid grounding is something I would avoid in MV, even though the US does it like crazy because every other MV-LV transformer is wye-wye.
As far as i'm aware, all of the local MV/LV distribution network TX's are Dyn 11 (delta/wye). N-E Resistors would only be used where it is requirement to limit the fault current on the LV side. Earthing electrodes for MV and LV systems are generally separated at TX locations unless the Ra value of the electrode systems are of a suitably low value (under 1 ohm).
I don't consider MV/MV TX's as being particularly part of a local network distribution system, although in Central and the City of London the networks have been reinforced and evolved many times often in not exactly the best way, so it wouldn't surprise me at all that N-E resistors have been used quite extensively.
UKMeterman
Small 11Kv cable fire London...
UKMeterman,
Knobhead,
