davesparks
So we do we stricly, and the version without the plastic bit are just ferrulesAhh, we call those bootlace ferrules.
I use wago 221's and fix them inside the enclosure with some double sided tape
No, what makes you think that? I use double sided tape to keep things neat inside j701's etc when using wagos for boilers too otherwise you end up with a mass of wagos exploding out of the box when you open it.the tape is a joke yes?
The tape will just fall off the side wont it? I would have thought you would have been better with something with a sticky back thats slightly more adhesive than tape, but I guess that would make a mess on removal.
not always ideal on solid strand conductors.Through crimps
