Guest viewing is limited
hi there guys,
I'm a lowly gas man but thought I would put my hand out to you helpful electricians to see if there is a better way to do the following!
I work for a rather large gas service and repair company and health and safety as I'm sure you will know is going a bit bonkers at the minute. Obviously I can see why but nevertheless I think there must be a better way than what they suggest to us.
Whenever I work on a boiler or system even if the spur is directly next to the appliance I have to remove the fuse and mechanically lock off the fused spur holder. At the minute the way we have been told to do it is with a tie wrap. Is there actually a proper item of kit hat will do this job instead of having to cut use cut use cut use tie wraps sometimes 4-5 times when in the house in between testing. It's bonkers I know but we have to do it so fair do's. I know they do a red box that you can fit under the two screws to the fused spur which you then can padlock but again that's adding more time to the situation
Hope someone can point me I the right direction
Kindest regards
Hisham
Yea they are the ones mate
See my post 2 you cannot rely on rubbish like that for safe isolation, you asked the question and have been given all the requirements for what is needed, yet you still seem to harp back to what your outfit tells you is correct, well it isn't correct.
could always use a fuse finder.
shopping
:D:D:D:D
Or maybe this onehttp://uk.rs-online.com/web/p/products/7047738/?grossPrice=Y&cm_mmc=UK-PLA-DS3A-_-google-_-PLA_UK_EN_Test_And_Measurement-_-Electrical_Test_Equipment-_-PRODUCT+GROUP&matchtype=&gclid=EAIaIQobChMIs62tsJO01gIVrbftCh0TcA2sEAYYAyABEgL8J_D_BwE&gclsrc=aw.ds
Scarborough
Business Name
BG
Safe fused sour isolation palava
Hisham Al-Bizri,
HandySparks,
