Hi, does anyone know off hand if any of the newer Crabtree RCDs will fit this board?
Need to replace it & can only find the 100ma ones.
This looks like a Crabtree consumer unit that I fitted in the 80's made from the hard plastic.do you know the name of the board ?. One option if you speak with Crabtree if the bus-bar is the same to fit a newer type in. The new type could be the same footprint to fit in or they should be able to tell you what it is from your photo.
around £50 is the issue for a 2nd hand part. £10 more can buy a dual RCD BG CU>
London
Old Crabtree RCCB replacement?
odawire,
odawire,
