Hi.
I am going to to new circuit at customer's dwelling and best way is to to do it outside of the house but laying cable on mortar/bricks.
Can I use twin&earth cable and use trunking or only armoured cable.
Mac
Don't use twin and earth, it will degrade in the sun, same reason not to use trunking. You can use SWA but this may be overkill if you're just running down a wall and the cable isn't going to be buried.
In scenarios like that I use NYY-J, commonly referred to as Hi Tough. It is suitable for external use, and comes in a variety of sizes and no. of cores. And is much easier to deal with than SWA for this kind of job.
Fix it to the wall with SWA cleats, jobs a good 'un.
Hi.
Mac
Where does the cable originate and what is it feeding ?
What about mechanical protection?
As @Gavin John Hyde says, it's tough stuff, but you have to use your loaf and only use it where appropriate. I might not put it low down behind bushes for example where someone might swing a spade, and I'd probably not use it down the side of a house where a car might get parked just in case, so use the same consideration you give any cable placement.
Wolverhampton
Website
http://www.morethanelectrician.co.uk/
Business Name
Electrical and LED Solutions
Type of cable to outbuilding but on bricks.
Mazak,
JK-Electrical,
