Hi as part of my job I have started doing minor maintenance in our warehouse and office block .I have a light out in the office which is a ceiling light that sits in the suspended ceiling .It operates as a normal light and when power is turned of for that lighting circuit the light also has a fitting inside that switches over to emergency lighting running on a battery I have only done domestic work over the years so have not come up against this sort of lighting my questions are
How easy is the it to replace the complete light ...how will it be wired and if emergency lighting is not needed how easy is it just to replace for a normal ceiling tile light these may be simple questions to some of you but as I haven't droped the light fitting down yet I just would like to be pre warned of what I'm up against
Thank you for reading my post
