It’s unlikely that they would round up an answer, if they have other answers to 2 decimal points.
Just have to calculate using both values, and if an outcome matches one of the answers, then that’s the answer.
k is either 115 or 143, depending if its single core cable or multicore. 160 is the temp.
143 is k value for thermosetting, 115 for thermoplastic, therefore answer is 3.67
As it is computerised, you have to be spot on with the answer, an assessor may have accepted 3.6 or 3.7 but I was marked incorrect on a computerised test paper for doing just that, rounding to nearest decimal point when the answer should have been to nearest 2 decimal points.
Sorry, 143 is also the value for thermoplastic single core cables.
My copy of the 18th (Table 43.1) only shows 1 figure for copper conductors, final temperature of 160deg C as k=115, for 70 deg C thermoplastic cables depending upon if less than 300sq mm.
Whether single or multicore cables, doesn't seem to have a bearing on the k figure (as far as the 18th and table 43.1 goes).
Either way 143 gives and answer (5.68s) which is obviously incorrect as it wasn't one of the multiple choice answers provided.
Another clue that it is incorrect! table 43.1 is for disconnection times upto 5seconds.
I just did mine and a very similar question did arise.
How much was your exam?
Mine was £125.
birmingham UK
Business Name
Power Capacitors LTD
Can't seem to find the answer, 18th edition tommorow ; )
stephen fenton,
tudore,
