Hello.
The toilet is connected into a cast iron waste/soil pipe O.D. 150mm.
Apparently, this is an extraneous conductive part and is thus supposed to have a main protective bonding conductor connected back to the MET.
There is a bonding clamp for 150mm O.D. pipes available.
However, the pipe will be painted to prevent further corrosion, so the contact with the clamp will be poor.
If paint is removed to contact the clamp, the pipe will corrode due to the high humidity of the location.
Would rather not drill or screw anything into the pipe.
What is the correct way to deal with this? If the pipe is painted so that it is not conductive enough to have continuity with a bonding clamp, perhaps it is not conductive enough to warrant bonding?
According to the regs, it seems this needs bonding. According to the EICR guide, missing main bonding is a code 2 fail.
Would any of you code a lack of bonding of a soil pipe on an EICR?
What is the standard way to deal with this and comply with the regs?
