Is the question still active or removed?Moved from DIY.
The question is still active and will get answered. Admin just moved the thread into the correct forum section.Is the question still active or removed?
Thank you. I'll just order the same unit then. I want sure if I could replace with a different light as the one I need isn't in stock. Typical! I'll find it somewhere.The question is still active and will get answered. Admin just moved the thread into the correct forum section.
Cant you get the exact same model? The number will be on it somewhere, and Luceco is a known brand. Just take the faulty one to a local electrical wholesaler and they will be able to source.
ebay or Amazon if it is a redundant model.
I also have never installed an integrated led downlight and never will. They are incredibly stupid and a money making scheme. I wonder how people explain to customers that when the downlight goes out the entire fitting must be changed rather than a lamp? It's bad enough enough floodlights etc are disposable but downlights are just ridiculous.This is why, out of all the downlighters I've installed, precisely zero have been integrated LED.
I agree Matt. I moved into this property last December and the cellar had been done out with 6 downlighters. I would never use these myself. Having a fitting with a replaceable bulb makes so much more sense.I also have never installed an integrated led downlight and never will. They are incredibly stupid and a money making scheme. I wonder how people explain to customers that when the downlight goes out the entire fitting must be changed rather than a lamp? It's bad enough enough floodlights etc are disposable but downlights are just ridiculous.
First of all, if I fit a number in a room, I supply the customer with a few spare lamps, and, failing that, it's no big deal to replace all the lamps.Both integrated and replaceable lamps have the problem that if, in a big room and you have 6,8, 10 or more, and one fails.
If you don’t get the exact same make, model, colour temp, lumens etc It is very obvious one has been changed.
Reply to the thread, titled "Can i replace a Downlight with one different to the rest?" which is posted in Lighting Forum on Electricians Forums.
