Had a look at a job a few days ago where, should the work go ahead, it would be necessary to run a cable under a flower bed. This is the only option acceptable to the customer unfortunately. The cable will be low voltage, ELV is not an option as the cable will supply power to sockets.
The flower bed is raised by about a foot, is narrow, and lies between a path and a fence. I suspect the concrete holding the fence posts will prevent me burying the cable to a decent depth.
Has anyone got any clever ways of protecting such a cable from damage when the flower beds get dug over?
Thanks for the comments guys, it's a great help.
The customer doesn't want the cable clipped to the fence unfortunately. She is quite particular about minimising visible cables. I'll not know until I start digging, but looking at it, I'm not at all confident I'll be able to get deep enough to avoid contact from spades when digging.
On a similar job I was able to run the cable in conduit, then bed a course of bricks of bricks on top. It worked well because there was brickwork immediately below the conduit too (it was a brick built raised bed), so was totally solid. I'm not sure that would work as well in this instance, as much of the run will probably be soil beneath. Perhaps that doesn't matter though.
A lot comes down to budget. There were once cable protection/marker bricks (?Baldwin) available that were perfect for this kind of thing but they don't seem to be as commonly available now, and the ones that turn up on line look expensive.
(And as I found out once, they aren't plumber proof when someone hands over the keys to a mini-digger...)
I'm assuming that galv conduit is too much of a faff to consider? Most manufacturers state it requires no extra anti-corrosion protection when in soil or concrete.
On that basis is galv trunking too expensive and over the top?
I'm surprised that manufacturers are suggesting galv conduit for direct burial in soil. I would've thought it would rust through eventually?
Warwickshire
Cable buried in a flower bed
Pretty Mouth,
nicebutdim,
