Neutrals at switches
G
Guest 004
Went to a job today, twin and earth, and it had been wired 2 plate, which of course meant that all the switches had the neutral taken to them.
WTF, if I had done that in my apprenticeship I would have been kicked off site.
Is this how things are done now, god I hope not.
It's a more convenient way of wiring downlighters, wall lights, or any other fitting without a 3 plate rose.
That said I'm not too keen on doing that in houses if I can help it.
Why not ask yourself ''what's right with it'' ??? Unless there is an actual need for a neutral at the switch point, then there shouldn't be any neutral conductors there, really very simples!! lol!!!
It;s been done like this for years..................agreed I was taught loop in/out at the ceiling and that is considered the norm, but would have no problems with an installtion done with neutrals in a switch ...........
Is there a reason you don't like it?
If there's no need for a neutral at the switch, then No i don't like it. A lot of this looping neutrals at the switch is more by laziness than for any real need. If you were wiring an outside light , fine bring a neutral to the switch. For down lighters, what's wrong with keeping the neutral conductor in the ceiling void??
Its much easier and safer making off terminations at switch height as opposed to hanging off steps ten foot in the air.
I was just writing that. As I said I was taught the conventional way, but there as been many a time when you have a loop in, loop out, and S/l/live up in a ceiling rose, where I wish there was just the one cable there, and I can mess about at the switch doing this.
Is it o.k takeing a Zs measurement at the switch though......
Guest 004,
Dan,
