S
StagsHeadNo.4
Is it a regulation to run a fly lead from the back box to the socket/switch. My point is, what if you had a metal 1 gang switch and you terminated your earth into the earth connection on the switch. I understand that when it's screwed back it would make contact with the metal back via the secure fixing lug, earthing the back box, but what if you wanted to cary out an ELI from this point. You would isolate the circuit remove the switch then re-energise to carry out the test. Potentially you could nick the cable with the back box and make it live as it would no longer be earthed.
I understand it would be good practice to run fly leads, but is it a regulation?
I know it's petty, but one of my engineers has come to me with this query and I just want to give him some feedback. Thankyou People.
