cooker switch above hob | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss cooker switch above hob in the UK Electrical Forum area at ElectriciansForums.net
South West
I went to look at a job last night where the customer wanted advice about fitting a new hob.
She'd already ordered one from john lewis but when they arrived to fit it they refused as the cooker switch was directly above the hob (bottom of the switch 600m above). Said they couldn't because of "new regulations".
Obviously i would never fit a switch above a hob on a new install but as this is an existing install would it be acceptable to fit the hob anyway. Ideally the switch should be moved..but to do that I'd have to take off about 3 tiles (no replacements), a wall unit to (to access the cable run) and I'd have to extend x1 10mm t&e cable (supply) and x2 6mm t&e cables (loads)
I guess the other option is to do away with the switch join the cables and fit a blank but can't really say this is improving matters.
She's had the appliances refunded but wanted to know if I could fit the hob. gut feeling is no but not sure what others would do.
Cheers
8 times out of 10 the C/U is in the kitchen anyway, ok it may be 4.23 meters away but at the end of the day "can it be turned off in case of a chip pan fire" (do people still have chip pans these days?)
Anything within the kitchen that is easily accessible is ok with me, as above, its local enough to be safe.
Yes!! .... You got a problem with that?? :angry_smile: .. :)
Is that anything like 4.23 metres? Can you be more specific with your measurements next time please
Ok you got me on that Trev lol.
Talking about measurements, picked this up the other month at a car boot for a quid. Spot the mistake???
[ElectriciansForums.net] cooker switch above hob
An old slide rule that says 1 foot = 3048 metres. Should say 30.48 centimeters. Tickled me so I got it for a pound, may be worth £2 due to the mistake pmsl.
thanks for the feedback.
I'll give her a ring tomorrow and run through some options. Poor ol' dear only wanted to treat herself to a nice new hob and gets a load of boring crap about Regulations! :)
Being old has it's advantages - one of which is that you tend to care less about silly regulations & things on the grounds that you've come this far in life without them relatively unscathed so why bother with them now!!
Reply to cooker switch above hob in the UK Electrical Forum area at ElectriciansForums.net
When you say plus kettle, does this indicate you are needing 13A socket/s on the island and a hob supply? and then an oven supply on a tall...
Obviously not a building/DIY forum so will keep it short but yes - we've taken all the floors up. Several joists in the bathroom need doing as...
Recommended Sponsor News
Hi everyone,
