Trying to convert 28VAC input to 120/240VAC or 9/36VDC.... | on ElectriciansForums
Guest viewing is limited
Discuss Trying to convert 28VAC input to 120/240VAC or 9/36VDC.... in the UK Electrical Forum area at ElectriciansForums.net
J
James9782
I have a query from a customer who is looking to buy a 5W product from me which runs on 120/240VAC or 9/36VDC. The problem is, they are in an isolated location where they only have a 28VAC power supply. I have looked around the web and cannot find any obvious solutions, does anyone know of any solutions/products which will solve this issue?
Best regards,
James
If the 28vac is at 50hz then and bridge rectifier will output at 100hz .....As Tony stated will need regulating..
Suggest bridge rectifier first...output to LM7815 reg, this will give stable 15v dc out.
omit transformer from diagram
[ElectriciansForums.net] Trying to convert 28VAC input to 120/240VAC or 9/36VDC....
If the 28VAC is from secondary of transformer with center tap, i.e. 14/0/14V, and ripple is not a problem to the lamp, I would suggest simpler solution by using 2 diodes to form a full wave rectifier, that will provide 0.9x RMS - 12.6 VDC.
Correct me if I am wrong.
Best regards,
James
I'm surprised that no one has suggested a transformer.
Seems to me it would be simplest and most obvious solution to get from 28Vac to 240Vac. Or 120Vac.
Yes Tel......so if the unit is 5w at 28v then current is 0.18a .....@ 120v current will only be 0.04a.
everything equals out between primary & secondary (increase one...decreases the other)
It will always be equal.....and wattage is the key....primary voltage is higher lower current......secondary voltage lover, higher current...put this in equation of total power for both and you can see current is proportional V/IR ...P/V
More correctly, it's VA.
Neglecting losses, you get
V[SUB]1[/SUB]I[SUB]1[/SUB] = V[SUB]2[/SUB]I[SUB]2[/SUB]
Reply to Trying to convert 28VAC input to 120/240VAC or 9/36VDC.... in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
