Odd request regarding phantom voltage! | on ElectriciansForums
Guest viewing is limited
Discuss Odd request regarding phantom voltage! in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Afternoon all...
I would like to experience phantom voltage!! Is there any way I can reproduce it so that I can test it?
I know this might sound a little silly, and I realise my new Drummond test lamp would simply not light up if it is phantom voltage, but I would just like to see it for myself on something that I know for certain is phantom voltage.
I also want to test the digital and analog volt meter on it so I can see what they record.
Again... I know this sounds daft but I just want to see it for myself.
Cheers guys.
You can probably "see" this in your own home.
Locate a circuit, turn it off at the CU then attach your MFT - you will probably "see" the phantom voltage as long as the cable(s) run parallel to live circuit(s)
My idea works every year...!!!
[ElectriciansForums.net] Odd request regarding phantom voltage!
You'll get a much larger phantom voltage if you wire a simple circuit using two twin and earth cables. Put a plug on one end of each of them but only connect the live in one plug and the neutral in the other, leave the other conductor unconnected.
If you use a nasty cheap multimeter which should have a ridiculously high input resistance you'll see a substantial phantom voltage between the unused conductors and earth.
Posted a couple of times about an easy way of demonstrating this...Get a length/roll of t&e,expose conductors at each end. Connect L and N at one end. At other end,measure between cpc/N or cpc/known earth. By using differing test instruments,the results can demonstrate both the merits of individual instruments,and,the reason why readings can occur. Also,by adding "links",of varying impedance,between sections of the circuit,you can replicate what you would encounter on an installation,and greatly assist the understanding of results. As incredibly sad as it sounds,some of the most fun i had,as a teenager,was setting up such arrangements,on a large 8' x 4' board,with all manner of purloined items,and inventing faults and scenarios,to test and understand. I suppose a modern risk assessment of such an enterprise,would today prove "troublesome" :bobby:
I have to admit that in my 22 year naval career I have never found nor heard of phantom voltages to be a problem. We had 'Wibers' for voltage checking, a version of a drummond lamp, but they were few and far between onboard, and most of us had to rely on our fluke multimeters to check for voltages. (I am well aware they exist).
A far more dangerous problem I feel is the 2mm tip rule and shrouds. If I do not get a voltage and expect one, I have always usually expected it to be there and if not have a damn good check. Nowadays with 'shrouds' I inevitably get some non contacts, and I will investigate further. I wonder if a 'churned out' Electrical Trainee would immediately assume safely isolated. The so called safety of shrouded tips is possibly actually a danger.
Reply to Odd request regarding phantom voltage! in the UK Electrical Forum area at ElectriciansForums.net
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
Second Update: 12/25/2023 Hey everyone, so I solved my doorbell issue. Turns out there were two reasons why my doorbell wasn't turning on. 1.)...
Recommended Sponsor News
Hi everyone,
