shop storage heater | on ElectriciansForums
Guest viewing is limited
Discuss shop storage heater in the UK Electrical Forum area at ElectriciansForums.net
multimick
ormskirk
small shop has one 2.5kw storage heater on one off peakcircuit via fcu however the shop only opens five days a week so are asking for a timer (7 day) so they can save heating an empty shop when not open.If i put a timer on off peak circuit it will stop at 8 in morning . Any ideas?
Install a 7 day timer, and match the timings or full 24hours during 5 day opening, and switch off at weekends.
Just to add, the timer will need to be run off normal cu to keep it running, and would suggest a contactor to control the storage heater
Used the standard cu to power the timer and contactor......then contactor controls heater..
[ElectriciansForums.net] shop storage heater
Reply to shop storage heater in the UK Electrical Forum area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
He can apply for an E7 tariff with or without storage heaters. It depends on his electricity usage profile on whether this is a good idea or not...
Recommended Sponsor News
Hi everyone,
