Quiet 6 inch wall fan | on ElectriciansForums
Discuss Quiet 6 inch wall fan in the UK Electrical Forum area at ElectriciansForums.net
Dru
Last week I installed what was supposed to be a reasonably quiet 6inch wall fan in a kitchen.
Turns out it wasn't as quiet as I anticipated.
Anybody know of a quiet one? Must be a 6inch wall mounted one
All help is appreciated
You installed them mate?
Quieter the better really. The one I installed is an xpelair
TBH no, but was recommended them in another thread. Others on here with more experience will advise. From my experience years ago installing them, make sure all fixings are sound and fan fitted square, blades flow freely, even at high speed.
You might be banging your head against a brick wall on this one. As far as I'm aware, manufacturers concentrate their noise reducing efforts on lower flowing 4" bathroom fans. The problem when going up to 6" is that by definition you will be shifting a lot more air - 60l/s usually. That's going to make some noise, whichever way you look at it. You may find a centrifugal fan quieter for the same flow (Nuaire Cyfan springs to mind), but you will have to close the hole in the wall down to 4 or 5 inches.
[ElectriciansForums.net] Quiet 6 inch wall fantry this
Reply to Quiet 6 inch wall fan in the UK Electrical Forum area at ElectriciansForums.net
Thanks for your advice guys. very helpful
I'll try and do a rough diagram here. But we have just connected it as shown in the diagram pictures I linked in the op
Ah OK, that makes sense. Thank you Avo.
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
