suitable j/box in loft are | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss suitable j/box in loft are in the UK Electrical Forum area at ElectriciansForums.net
England
Not a lot to day so yet another question. Got several (about 10) 1.mm lighting cables to join together in a loft space which has about 300mm + loft insulation.
Years ago I would of used a J701 j/box with chocs blocks. Anything better on the market now? Would you guys fix the j/box above the joist level and the remove the insulation so as not on top but still some underneath?
Why wouldn't it comply? It comes with a small mounting bracket so as not to compromise the IP rating of the box but you can still fix it securely to a surface and the knockouts are rubberised so you can poke cables through. Although they do have internally threaded sections so there is no lock nut required when putting a stuffer in there.
As Dave has said, in its current form it would not comply as there are no cable grips!
Looks neat, thanks. Basically a few feeds L+N's + a couple of 3 core sw/wires + several cables to lights. Are those boxes pre-wired then? Would that restrict my wiring options as opposed to starting from scratch?
Yes they are pre wired, i have found no restrictions with them. The only downside being that with the short connections on the push fit terminals, if the wires are connected it is hard to tell if one is loose, just takes a little extra checking.
I clip the cables once the box is secured.
Although i have been guilty of leaving jbs loose(ish) in certain situations. I only use glands with Wiska boxes when they are either on show or in a potentially damp environment. Because i am a tight arse!
Assuming you are connecting multiple lighting circuits, i have used surewire boxes and they look very neat. Surewire - Pre-wired Maintenance Free Lighting Junction Boxes
Interesting colours in bottom cable 2nd from right... alright, not exactly helpful, but you must admit, observant :sorcerer:
[ElectriciansForums.net] suitable j/box in loft are
Good point but I've not come across it
It's crap mate. I used it on a rewire then spent 20 minutes identifying the seperate conductors. At least with standard brn/blu you know which is your switch feed and return.
Nice idea but pointless. I am probably going to end up using it as standard t and e and sleeving one of the browns blue lol
Reply to suitable j/box in loft are in the UK Electrical Forum area at ElectriciansForums.net
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Recommended Sponsor News
Hi everyone,
