Does anyone know where to get RCBO's for this... Steeple? | on ElectriciansForums
Discuss Does anyone know where to get RCBO's for this... Steeple? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I've found one 32A RCBO (double way), but I know you can get single way Steeple RCBO's as I've seen them, but I just cant see them anymore!!
Does anyone know where to find RCBO's that will fit this Consumer Unit? I need x3 32A and x1 6A...
I have spent quite a while looking!
Ebay has the x1 (double) 32A RCBO. Dont think Denhams do them anymore, will ring tomorrow... anyone?
I know it's not good practise and I have not had to do it yet, but do other RCBO's fit this CU?
[ElectriciansForums.net] Does anyone know where to get RCBO's for this... Steeple?[ElectriciansForums.net] Does anyone know where to get RCBO's for this... Steeple?
That looks a lot like an old GE board with a different badge printed on it.
Yes, have just read that they were GE.
Here is another picture which shows the RCBO's required, and the fact that there are 2 different types and they dont fit well together.. makes it even harder to determine which I need!
Nope, those in the picture are almost certainly Wylex/Crabtree rebrands, not the same as the GE rebrands in your OP
This is getting confusing! So the ones in the second picture say 'Steeple', but are rebrands and wouldn't fit my board in the first picture?
Just checked my Denmans catalogue and they are still available.
Thanks IL, I'll give them a ring tomorrow but I'm not holding my breath.
Do any others fit htis board... crabtree loadstar?
The first pic of the old steeple E series was indeed GE, the new steeple stuff doesn't fit these boards, Denmans don't do it anymore anyway although it was a wylex rebrand so wylex stuff fits the newer steeple boards.
I've never seen an RCBO for the old E series though.
Looks like I will have to change the board then.. I shall remember this next time I come across an E series!
Thanks for all the help guys..
Have you called Denmans? The grey RCBOs in your last picture look quite modern.
Yep, called Denmans this morning. They have plenty of Steeple RCBO's as in the second picture, but like the others have said, this is a GE board (rebranded as Steeple) and they will not fit. Denmans said they were unaware of any GE RCBO's
Find a mcb to fit the board and feed a sub board of that if your struggling to get a rcbo
I guess so.. but it's going to look even more messy then and theres not much room anyway, so new board it is. I'd love to just pop the sockets and lights over to the RCD protected side but I'm not going to as that just wouldn't be cricket!
nothing wrong with the old board... get one of existing rcbo out, take it to a place stocking good range of kit, compare it to some others. as long there is a din rail and a bus bar you should find something suitable...
Whatever it is the RCBO is needed for, can it not just go on an mcb on the existing RCD split?
It could Dave, but It is a fairly large refurbishment, so I shall be playing about with the cooker switch, sockets and light circuit all on the unprotected side... all involving new chasing, so I want them all RCD protected. It would be a bit like just having an RCD as a main switch if I moved them all over... so not great.
Why take the output from the relevent MCB to a stand alone RCD unit, with the output going back to the board to connect up with the relevent circuit, or if there is enough slack on the circuit, take that into the output of the RCD. Could look a bit messy with 3 circuits though.
Would achieve the same as RCBOs.
You could put 3 RCDs in an empty 6 way board.
I sincerely hope that when you say 'playing about with' you don't actually mean that.
If you are working on a significant number of circuits then it would quite possibly be a sensible time to discuss replacing that CU.
Reply to Does anyone know where to get RCBO's for this... Steeple? in the UK Electrical Forum area at ElectriciansForums.net
What I find a little bit interesting is that there was an era of MFT's e.g. Robin, early Kewtech that tried to do non-trip loop tests using D-Lok...
Single Pole, Single Pole Switched Neutral, and Double Pole are all different things. Hager RCBO's are Single Pole. I was recommending Single Pole...
5K
  • Locked
  • Solved
Therein lies the problem. I see no merit in further circular debate, so will bow out of this discussion.
7K
nicebutdim
N
Heh I know the brochures for courses with stock images of women using tools in random scenarios but when you're there it never happens, it's all...
