I have some works at a small flat (4 properties). PME. Service head has been doubled up by DNO, so that supply cable for the second head exits the bottom and feeds the second.
I find a 6mm green/yellow conductor strung between the PME break-outs of the two heads. It looks like the unusual work of a previous installer who didn't know what they were doing. (I have other earthing/bonding to sort to so here that wouldn't be surprising).
But what is odd is both break-outs have DNO seals, which were added after said cable, which implies DNO may have wanted it there (or perhaps they were laughing so much they couldn't be bothered to remove it?)
So WTF is that 6mm cable? Might it be the work of DNO? If so, - why? Note: gas/water bond should (read will..) run only to the MET off the first head. On this basis if the cable were 16mm might it be described as combined bonding/earthing for the RHS suply? - Only the PME in the supply cable between the heads is surely performing that function anyway.
(Please restrain comments on the 10mm tails and 100A fuse.. yes there is work to do here..)
Clicky for full pic..
