E
Eddiesparks
This sounds like a daft question but i am doing an install that requires lighting in the common area and of course emergency escape lighting.
I am thinking of installing something like this which I assume requires a perm live, a neutral and earth to each (can't see a need for three core plus earth for these but maybe I am wrong! The integral sensor means they only need a perm live right?!
They have integral sensor so they come on when people go near them and they also work as emergency lights. My question is firstly, have i got the above all correct and also would i need a keyswitch at source to test them (surely the mcb would do the same job in this case?!) or would you know they are working because the lamps are working in normal operation.
Apologies for my ignorance in this,
https://www.tlc-direct.co.uk/Products/LTPMESW.html
Thanks people
Thanks people
