Does this comply - Zone 1 | on ElectriciansForums
Guest viewing is limited
Discuss Does this comply - Zone 1 in the UK Electrical Forum area at ElectriciansForums.net
Wales
Hi all
https://www.dropbox.com/sc/vpnieno3z1xuxna/AAA_qOcvnyVCb-ZRiBAtQFb1a
https://www.dropbox.com/sc/naxnji157w6chkt/AAABxHKzpVMWPUElrt-d6fQga
Does this comply with BS7671?
They are posisioned within 700mm of a shower within a wetroom. Within zone 1 - no permanent fixed partition! with no basin!
I note that these are electronic switching with the 230v supply into the rear of the switch!
I note regulation 701.512.3: In Zone 1: only switches of SELV circuits supplied at a nominal voltage not exceeding 12a.c. rms or 30v ripple free d.c. shell be installed, the safety source being outside zones 0, 1, 2
Probably not compliant then, though reasonably safe as it would require a concerted effort to spray water on them.
I assume you have taken the distance of the barrier into account as well for the 700mm measurement.
Was it converted to a wet room from a shower?
Yes it was a shower room - the distance from the shower screen (movable) is 300mm
Distance from water outlet to screen is 400mm
This work was done by a plumber
He also installed an electric U/F heating Mat - No iso and the below pic - found in the attic
https://www.dropbox.com/sc/m7j7ju3ehy1qmae/AAAxpLXCSSfNRa_J8NU4yyQ7a
also this in a cupboard next to the oven
https://www.dropbox.com/sc/vq3whaup495xwb2/AADWPDnnMp3YZpGswPyrgptUa
He charged £175 to change the oven and this lovely job!
For the bathroom he charged well over £2,000.00
The distance could then be compliant as you have to take into account any barriers (assuming they are up to 2.25m)
[ElectriciansForums.net] Does this comply - Zone 1
The rest of the pictures are abysmal, it seems he is short on earth sleeving and junction boxes!!
No the barrier is not upto 2.25m - it is only about 1.8m
Also the bottom of the barrier starts at about 1m off the floor.
This barrier can swing from side to side - I thought this rule only applies to fixed barriers not non-fixed
Overall the work is not good quality.
I think the barrier is a fixed permanent partition it cannot be removed and would provide a barrier wherever it was unless it can fold back into the shower cubicle.
However the height means it is not relevant.
Poor work high cost.
Sorry to reopen this, need a hand with a quick question I cant answer
Same property - the Electric underfloor heating has only been installed in zone 1 (in the shower area of the wetroom)
Does this comply?
I have checked the regs but cant find anything suggesting either way.
Any help is greatly accepted.
Before anyone asks I dont have any spec on the E-UFH, all I know is the control (seen in post 1) switches 230v A.C. to the mat and has a thermostat buried (in the floor - I can only guess!) The cables are already buried in the wall after a plumber attempted and hashed it up!
This E-UFH is layed upto 2 inches from the drain
As far as the actual under floor matt goes, its under the floor therefore I would not class it as in a zone rather in a location containing a bath or shower - however it should be RCD protected and have an earthed grid/sheath.
Reply to Does this comply - Zone 1 in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
Wales
