H
hightower
Anybody ever come across this? Basically, 2-way lighting (old hence old colours). 3-core goes to both switches and that is the only cable to enter the switches. The 3-core runs to a junction box - the blue and red are straight through (uncut), the yellow is cut, one end wired to the supply, the other end wired to the light. The return from the light is then wired straight in to the supply neutral.
This is a currently working circuit I came across yesterday - I can see how it works etc, I was just wondering if others have come across wiring like this before and why it would be done like this? In this example I came across it on a landing light with upstairs/downstairs switching.
The back boxes were shallow, so I wonder if it was done this way to limit cables entering the boxes in limited space? Is something like this fairly common practice?
