Came across this today? | on ElectriciansForums
Discuss Came across this today? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I expect this will be an easy one for most of you, but as I haven't been in the game for long I didn't have a clue what it was until I opened it up!
Any ideas? :D
[ElectriciansForums.net] Came across this today?
All the best kitchens of a certain era used to have them. Then they invented quartz battery powered clocks.
Still available (but expensive). Also used for picture lights as it's a really low profile connector if you use the flush sort.
It's a ccu - a clock connection unit ! (Fused)
Why's it called a 'clock' connection unit Murdoch? One fuse was feeding one light and the other fuse the rest of the lighting circuit.
Hmm. Well we were wrong then.
Clock connection unit is just a special type of fused plug and socket. It has a flex outlet in the bit you unplug, which I assumed was present, but not visible in the original pic.
So it's just an early type of FCU (both poles)?
MK did make a clock point that looked similar but with a flex outlet. It's not an FCU for connecting to an RFC - you wouldn't get the cables into its terminals - but it serves the same purpose. You might fuse down a larger radial to serve a small circuit or appliance that required protection (e.g. the bell transformer mentioned) just as we fuse a 6A circuit locally to 3A for an extractor fan. Fuses are BS646, 1, 2, 3 or 5A. It's DP because of its age, although by the 50's SP fusing was becoming standard because the ESR had declared the neutral as solidly earthed and the 11th edition was revised to align with it.
Stand-alone inline fuse units had a long history before the FCU, partly because of the tree system where fuses were located throughout the installation (i.e. not grouped at distribution boards) to minimise length and number of cable runs. A century ago they would have been a pair of pepperpots on a pattress, this was the next evolutionary step.
Reply to Came across this today? in the UK Electrical Forum area at ElectriciansForums.net
Ouch. Danger notice to customer in my book.
Yes agreed this is definitely out of my comfort zone and it was from the start. Connecting the lights on to scaffold just had me on edge. So the...
Well yes obviously, but if the transformer is indoors and your lights are 50m down the garden then it's very easy to need pretty big cables at...
That explanation would make a lot of sense and would certainly explain the new bases and new boxes, with old relabelled alarm heads. I do remember...
  • Solved
There is an article about that here: https://www.cement.org/learn/concrete-technology/durability/corrosion-of-embedded-materials It states...
