Flashing LED's | on ElectriciansForums
Guest viewing is limited
Discuss Flashing LED's in the UK Electrical Forum area at ElectriciansForums.net
I have a friend that has had 4 under cupboard LED Lights fitted. They are connected to an LED Driver - it is a 24V DC LED Driver 100W. However when they switch on the leds they just flash, Can anyone help with this and how to get them working properly? Thanks
Yeah they tried that and changed the driver, as thought it was faulty but problem still remains...
Tried what? Calling the electrician back?
It's could be a mismatch of driver to LED, incorrectly wired LEDs, a fault in the wiring causing the driver to fail, a fault in the supply to the driver, a dimmer supply being fed to a non dimmable driver
Of course he didn't, he is just asking on behalf of a 'friend' who had them fitted.
I do hope you aren't suggesting that someone would have a go at electrics, cock it up, then come on here for help to extricate themselves from the excrement.
Look fella's, this installation was done by an niceic registered electrician, it is only after the event My "friend" has asked me to take a look as the electrician that fitted them has moved out of the area. I mistakenly thought this site was for Helpful advice and not to make incinuations on my ability or honesty. Nevermind fellas, i'll do my own research seeing as you have no useful advice.
Look fella's, this installation was done by an niceic registered electrician, it is only after the event My "friend" has asked me to take a look as the electrician that fitted them has moved out of the area. I mistakenly thought this site was for Helpful advice and not to make insinuations on my ability or honesty. Never mind fellas, i'll do my own research seeing as you have no useful advice.
You have more than 10 posts - can you post a picture of the transformer? I suspect the LED's don't have a high enough load for the transformer!
How long ago were they fitted? Moving out of the area is no excuse, your friend should not have to pay to put right something they have already paid for within a reasonable timespan.
The title of this site should give something away, 'electricians forum', a place for electricians to gather and talk, not a free public advisory service.
Yes I agree he should not have to pay, and I am an electrician, I am just trying to put right someone else's shoddy work, I am baffled by it and I am on here trying to get some help. the original leccy is some 100 miles away now and not interested anymore. I would like to fix it for my mate as cheaply as possible so he is not spending a fortune on other drivers. As I Say there are four LEDs and are switched via a normal 1 gang switch - no dimmer. pics attached - hopefully [ElectriciansForums.net] Flashing LED's[ElectriciansForums.net] Flashing LED's
Reply to Flashing LED's in the UK Electrical Forum area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
Recommended Sponsor News
Hi everyone,
Flashing LED's
