The switch is the right way up.
yes you are right.
Discuss REC switch and meter seals... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Although you'd normally see the incoming at the top and outgoing at the bottom.
Reply to REC switch and meter seals... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
