Tripping issue....ideas needed! | on ElectriciansForums
Discuss Tripping issue....ideas needed! in the UK Electrical Forum area at ElectriciansForums.net
Leesparkykent
Nearly Esteemed
Kent
Looking for ideas... completed a job recently of 11 new build houses and above the open staircase we have installed a rope light made by Tamlite similar to the one in the pic. This light is two way as above the stairs. On 3 of the property's every now and again the MCB for this circuit trips when either of the two way is switched (note this doesn't happen all the time, probably once in every 25). I'm sure most of the regulars on here will know I've conducted the relevant tests such as insulation resistance etc and comes back >299 on all including the two way in all positions. The transformer is mounted in a stud wall with no insulation and a little access trap. What do you think the problem could be....my thinking now is a dodgy batch of transformers but was wondering if anyone else has ever experienced similar problems? Ps It all comes part of a kit with 5 x mr16 lamps.
[ElectriciansForums.net] Tripping issue....ideas needed!
Is it a proper (wire wound) transformer or an electronic one?
I've had the exact same problem with a bunch of external firings which used proper transformers, I think it ended up on a 10A D type to cope with the inrush.
I know a lot of those things have a toroidal transformer in a decorative box. If possible try an electronic transformer (I'm pretty sure aurora make a 250VA one)
Inrush current when the lights are switched on, seen it before.
Yeah its definitely a wire wound transformer.
I fitted yards and yards of something similar in our old offices and had all sorts of headaches with inrush. I ended up changing some of the transformers to better ones. A couple of them might have got converted to electronic, but proper 12V DC PSUs not electronic lighting transformers with HF output, as the cables would have been well over the permitted max length and might have radiated hellish interference.
I'v had this problem before. If it is a wire round TX then I'd agree the initial inrush of energising an inductive load is highly likely your issue. Your only hope I feel will be to use Type C or D MCB's. Hopefully you've a good Zs!!
Regards
Regards
The houses are tiny and bang next to the substation so shouldn't be an issue lol
Reply to Tripping issue....ideas needed! in the UK Electrical Forum area at ElectriciansForums.net
I fitted a Mem MR30 Pod and MCB, about ÂŁ75 for both.
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
