Discuss Overloads? in the UK Electrical Forum area at ElectriciansForums.net
I would suggest the builder of this panel is clued up about how to design controls and circuits but is lacking in knowledge of the BS60204 as they have cherry picked certain reg's and totally ignored others, also I would suggest a PLC would have simplified this set-up greatly.
Do vsd's take in single phase and spit out 3ph
Vsds can be single phase in or 3 phase in. All output 3 phase. They output the same voltage as they are inputted (no doubt there will be exceptions but none that I have seen) ie 230v in single phase = 230v 3 phase out.
400v 3 phase in = 400v 3 phase out.
It may not be compliant with the machine regs but I regularly come across panels a lot worse than that. Just out of interest what's the component that's mounted at the front right of the base of the enclosure?
FFI?
Sent from my iPad using Tapatalk
I've seen worse like this work of Art.
Reply to Overloads? in the UK Electrical Forum area at ElectriciansForums.net
