Asbestos light switch accessory boxes | on ElectriciansForums
Discuss Asbestos light switch accessory boxes in the UK Electrical Forum area at ElectriciansForums.net
Notts
I've come across what I think are asbestos accessory boxes. 1938 wire VR. Just popped light switch off and came across this. What do you think?
[ElectriciansForums.net] Asbestos light switch accessory boxes
worth showing your findings to whoever ordered the work, there are companies to call for inspection and removal of the stuff.
if they not bother then invest in a proper mask and a tyvek suit if you planning to disturb it.
Have only seen wooden back boxes that look like that, think it's just old and not been loved, take it out and send some more pics, might be wrong as l am only 48 maybe some one like tel can shed some light on it
Sent from my iPhone using Tapatalk
It looks like it could be what we used to call 'millboard' when I was an apprentice. Usually it was used in wooden cupboards that had electrical equipment in them. We used to get it in a large sheet and hand-cut it into panels to internally clad the cupboard to make it flash-proof or fire resistant. That said I've never seen it used on its own in cement but I'd suggest you get it checked out according to whatever your local regulations dictate. Without seeing the texture of it first hand and giving it a prod with a screwdriver it's impossible to say if it's asbestos or not.
Agree it looks like a regular wooden back-box. The sides usually taper to a thin section around the front edge that we can see, which makes them look thinner than they are and more like a sheet material. If you touch a drop of water on the cleanest part you can find, the colour of the wood might show through, and you won't disturb any dust. I have also never seen a light switch box made of asbestos cement board.
Reply to Asbestos light switch accessory boxes in the UK Electrical Forum area at ElectriciansForums.net
Hello Brianmoooore, Thanks for yor reply - Sorry that I did not see your message until today - the Forum replies notification emails about your...
