Would you bond this in.... | on ElectriciansForums
Discuss Would you bond this in.... in the UK Electrical Forum area at ElectriciansForums.net
Notts
Would you bond this in the meter cupboard. Although outside the property if you look at the pipe work it branches off and one branch runs externally all the way around the property.
[ElectriciansForums.net] Would you bond this in....
Reply to Would you bond this in.... in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the replies, I appreciate it.
Bonding cables don't need to be insulated, other than for a short section at the end to identify them, and as long as they're 4mm2 or greater are...
