davesparks
Does anyone know where I could get a new meter movement / needle assembly for a robin K3131DL insulation resistance and continuity tester? Or even just a part number for it, I've got the service manual but that seems to list every component except the movement.
Mine is broken and I can't find a new movement or a replacement tester at a sensible price from the usual sources.
Hopefully parts are available as kewtech are still manufacturing what is essentially the same tester but under their own brand and part number.
is it the same as this:
Meter movement
davesparks,
davesparks,
