Anti Corrosive Fluorescent Fittings | on ElectriciansForums
Discuss Anti Corrosive Fluorescent Fittings in the UK Electrical Forum area at ElectriciansForums.net
H
Hawk
Does anyone else ever have problems with anti corrosive fluorescent fittings giving way. The base seems to become brittle overtime causing the fitting to giveway even when using washers. Just back from a job where the fitting had dropped from the ceiling. Luckily it didn't fall on anyone.
Any solutions appreciated.
[ElectriciansForums.net] Anti Corrosive Fluorescent Fittings
Most of them come with proprietary clips to fix them with. Never had a problem when using these as they can be used for either suspended or direct fixing.
I have also come accross a lot these weatherproof fittings where the spine has split around the fixings even though these older types allowed for fixing straight through the fitting with a rubber washered screw. I hate this new design with a spring clip it can make replacing a existing fitting a real pain especially where the cable/flex is fed through the ceiling like in a cold room.
Reply to Anti Corrosive Fluorescent Fittings in the UK Electrical Forum area at ElectriciansForums.net
Problems can arise when you get on too well then they think he won’t mind me doing a bit.
    • Friendly
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
