Go to choice of white plastic accessories. | on ElectriciansForums
Discuss Go to choice of white plastic accessories. in the UK Electrical Forum area at ElectriciansForums.net
Leesparkykent
Nearly Esteemed
Kent
My 1st choice is Click mode...What I like about the switches is you can change the modules so for example you can have an intermediate and 2 way switch on the same 2gang plate.
Probably Crabtree because I consider them to be a happy medium between price, quality, availability and consistency. In reality I usually seem to continue whatever make is already being used, so it's useful when what is already being used is something readily available, like Crabtree or MK.
I don't think I've ever come across Click Mode; while I agree they look flexible I don't think I've ever found myself in a situation where I couldn't use something off the shelf from Crabtree, with the possible exception of a grid for kitchen appliances.
Contrary to Will, I'd say that Hager Sollysta is some of the best quality stuff I've used, however I tend to use Click Mode simply because of the convenience and price of the minigrid stuff. The quality is reasonable on most of it, but there are a few bits that are a bit iffy (the minigrid flex outlets for example seem to disintegrate fairly easily and I've had quite a few dimmer failures).
Hager Sollysta for me for my basic white plastic choice.
It's a good wide range with top build quality, pretty good looking, really well designed for ease of installation and testing, and the price is only a small percentage more than the basic square edged ranges I would class as a compromise on both quality and looks.
The switch modules are interchangeable on the plate switches too apart from the 3 gang on a single plate, which is one moulded module.
All switches feature a neutral loop terminal.
They also have a grid range to match which offers flexibility when needed.
I have used click mode before, but generally in a decorative option. When a decorative option is needed with flexible requirements such as a kitchen fit, I look at whichever range suits the install.
with the hager sollysta range do they do media/euro plates and modules like sat, tv, bt etc? Ive used the hager range before on a office refit and liked the switches because of the neutral terminal.
Yes they do. I have just finished a print shop data job, around 40 points, using Hager euro plates with cat6 modules. Lovely quality modules with a very slim profile. The budget brand modules I was offered by my wholesaler were that bulky front to back they would not even fit in a 25mm trunking box.
This is their euro module range
White Moulded Euro Accomodation Plates & Modules White Moulded - http://www.hager.co.uk/product-catalogue/wiring-accessories/sollysta/white-moulded/white-moulded-euro-accomodation-plates-modules/58361.htm
Click Mode for white, and for decorative as well...gives some great options like this (D/W, W/M Isolators and a Fuse for Mood Lighting which is controlled by sensors)
[ElectriciansForums.net] Go to choice of white plastic accessories.
Them 3.5 screws would bug be lol..I would have to get the slots on each screw vertical :eek:
Reply to Go to choice of white plastic accessories. in the UK Electrical Forum area at ElectriciansForums.net
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
