Im relatively freshly qualified and registered so still coming up against new challenges.
I have a client who has requested a rewire but they also want minimum damage to flooring etc. Hopefully loft access means I can get to first floor lighting cables but ground floor ceiling lighting could be tricky.
Provided testing on current cabling comes within correct values is it okay to reuse??
Also, whilst sticking with safe zones is it acceptable to chase around corners, I presume as my chasing tool won't get right into the corners a chisel will have to do the tight spot?
As a side note, install has every variety of back box surface mounted even with big fat finger holes, L/N reversed, sockets with no Earth, trailing cables in front of doors no main earth supply - otherwise its perfect!!!
