If someone asks you to install one of these avoid if you can. | on ElectriciansForums
Discuss If someone asks you to install one of these avoid if you can. in the UK Electrical Forum area at ElectriciansForums.net
Dave OCD
Mentor
Cornwall
A hand made glass chandelier from Italy , cost unknown but not cheap. The customer brought this back from Bermuda in 3 cardboard boxes and we had to assemble then fit to the vaulted ceiling in a converted attic bedroom. I also had to find E12 Candle Lamps which nobody stocks. The picture doesn't really show the size and it must weigh 20kg+ . Had to use the size of ply shown to get decent fixings , a tricky job from start to finish. :)
[ElectriciansForums.net] If someone asks you to install one of these avoid if you can.
Here is one I fitted recently. Fortunately they got a builder to reinforce the ceiling beforehand because it was a heavy thing and we could only get up there safely on a platform. It came from a well known shop in London that begins with an H and it cost over ÂŁ1100.00!
All well and good but the customer didn't want any digging out /mess [not to mention 'safe' zones] and a circular support would be impossible - not too clear on the picture but the ply spans the angle of the roofline.
You think that's bad, I helped install this chandelier, ÂŁ150k! Must have been 15m long at least through 4 floors down to basement level. Hung from threaded rod studs cast into a concrete reinforced ceiling! This is in sir Robert Walpole house opposite the Ritz hotel in London.
All the crystals were hung one by one by hand., made by Swarovski.
Reply to If someone asks you to install one of these avoid if you can. in the UK Electrical Forum area at ElectriciansForums.net
