T
Toneyz
Anyway when is the book coming out ?.It was me Pete999 no shame no gain
Discuss What cable type is this? SWA? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Already in draft, waiting for clearanceAnyway when is the book coming out ?.
hmm i need to polish up my Polish. then i can understand what 'er indoors , her mam, and daughter are saying about me when they think i can't.I think you need to
Polish up your spelling.
TattleWhat's the tittle?
The spark who came in from the cold?
Not needed. As was said earlier, the sheath is already earthed (needs checking and testing) via the earthed pot.You can get boxes that clamp the pot inside so you wouldn't need to reterminate the cable to fit a gland
K2131 WHI - https://www.mkelectric.com/en-gb/Products/WD/BoxesandAncillaryProducts/boxes/mouldedboxes/m1cable37mm/Pages/K2131WHI.aspxNot needed. As was said earlier, the sheath is already earthed (needs checking and testing) via the earthed pot.
If you can find a suitable method of box cable entry for the potted pyro end it can be connected safely.
hippy beads?Is my memory at fault ? (as is usually the case)
I have this memory as a apprentice of using beads rather than neoprene as the conductor insulation for pyro ends
Reply to What cable type is this? SWA? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
