Bit of a challenge for me | on ElectriciansForums
Discuss Bit of a challenge for me in the UK Electrical Forum area at ElectriciansForums.net
Suffolk
Probably all in a days work for a professional electrician but it had me scratching my head. I wanted to fit lighting into a room but there is an en suite on the floor above, as you can see I made a hole in the ceiling and worked from underneath.
[ElectriciansForums.net] Bit of a challenge for me
What size cable is that? only it looks a bit bulky for lighting applications
Looks a bit of a sorry mess I have to say. Gonna need an MF JB above the ceiling, when there was no need to have any JB at all. Only 1 cable at the fan isolator, and good luck setting any kind of box into that mess of a hole for the fan isolator on what's now a skimmed wall.
Reply to Bit of a challenge for me in the UK Electrical Forum area at ElectriciansForums.net
Typical! If they've used plasterboard screws in a bathroom they'll fail anyway they're not meant for wet areas. So I bet the wrong adhesive was...
    • Winner
People who claim to be plumbers... and tilers... New bath fitted and the drain is accessible from the side and there are isolating valves on the...
