MFS Electrical
Mentor
apologies if this has been covered anywhere else but I’ve looked and can’t find anything... so a customer has asked if we could change a light in their stairwell and I have to admit I’m at a loss as to how to do it safely? The stairwell is a lot like the one in this video but I’m not sure that this platform thing is the way to go.... anyone else done any similar jobs that could help me out or have a more cost effective solution was thinking of Using our stair ladders but the new light is quite heavy and fiddly so ideally I would like to have two men up there to take the weight of it etc so that kinda rules out the stair ladders any thoughts.
4 part ladder, bend the top part to 90 degrees and presto safe and sound! You know the ones that click into place and have four equal parts and a stabiliser each end and can be used as a platform.
https://www.amazon.co.uk/Youngman-576704-Multi-Purpose-Ladder/dp/B00H84Y3J0 and they can't fall sideways as the walls stop that.
Or a three way combi ladder 7 or 8 rung. The first part of the ladder can be reversed for stairswells.
Combination Ladders | Ladders | BPS Access Solutions - https://www.laddersandscaffoldtowers.co.uk/acatalog/Combination-Ladders.html?gclid=EAIaIQobChMIxavS3pjW2gIVT7vtCh1IzwoVEAAYASAAEgL2WvD_BwE
As an Amazon Associate we earn from qualifying purchases.
i have one of them fold up 4 way ladders in my van, they have bars that attach to feet and very stable, can use in all sorts of situations and fold up nice and small.
the offset as @Vortigern suggested is ideal for stairs. failing that when in some old georgian properties with huge stairwells, i have before now hired a proper mini tower in and installed across both sides of the stairwell, using the locked feet to account for height differences. then run platforms across the 'gap' just be sure to put the rails on!
the job that required this was one of them daft lights that all hang at varying heights, had 12 of them in all, each stopping at different points, one on each half landing.. also had colour changing smart bulbs in so it could reflect the owners mood!
On a large chandelier I fitted a couple of years ago, I used two methods of fixing. I used a gripple wire, pulled through the loft, that helped me hoist it to near enough in place, it also helped when I needed to rest my arms when installing the hard fixings, with the safe knowledge it wasn't going to fall to the ground.
I used an A frame ladder, but there was considerable space to use this, I have since purchased a stair ladder of which needs time to gain confidence that it wont bend in half, as they look and feel rather carp.
It was you wasn't it................
Was wondering whether the yank was building a house within a house,but no he wanted to work on a light
It sure was one convoluted means of getting to a light fitting:eek:
Ladder against wall,plank across banister to ladder,steps to get up on plank, yet another piddling little job bites the dust:rolleyes:
I suppose it can be done in a few days with the H+S method,sadly I never subscribed to make mountains out of molehills by fixating on that particular obsession:)
A long extension ladder with a ladder stand off to bring you nearer the light, when stair ladders don't reach, is one option I have used. Similar to the 90° bend on the multipurpose ladders but longer length, but not so far off the wall.
I tend to use a plasterboard support prop, possibly at an (slight) angle from the top floor (as they are not long enough to reach up the stairwell) to support a light fitting whilst connecting / fixing. I even managed to balance one on a cross beam when fixing a heavy brass chandelier about 5m up!
I know seems a lot of work to change a lighto_O we ended up using our stair ladder on the lower stairs and an extension ladder jammed against the top step and the opposite wall but it was a bit Ropey cause the light was heavy as hell:sweatsmile:
thanks for all the advice, it’s much appreciated nice to have some people who can help you look at things from a different perspective :praying:
Come on seriously? really? no idea at all? please chip in then we can chip in.
To be honest I did have some ideas but they were either to build some sort of platform or hire a stair scaffold and I didnt really want to do any of those because it would have been a massive PITA I just couldn’t see any way of being able to do it with ladders when it really needed two men to do it.
Think I've put this up before. Little Giant ladder. I've used it a few times in various ways on stairwells. I got the customer to take the weight while I attached it to the ceiling.
Love it mate I’ll stick it in the van next to my ladders just for future reference :tearsofjoy: only thing is that light looks like it’s still on :tongueclosed:
yeah it had occurred to me that working live from scaffold tower may not have illustrated to the letter of the regs the correct procedure
thing is about that drawing it is remarkably close to one of my logbook entries lol
Did you copy mine ????? I remember sitting in the works van drawing a masterpiece just like that 5 mins before I was due to see my sectt training officer :sweat: found out that I’m pretty good under pressure that day might well have been the best drawing in the book close tie between that and a pair of yellow steps
my guys hard hat was a top hat, his boots cowboy boots with steel toe caps of course
Hope you didn’t forget the spurs and the horse in the background
here is an example for a 2 man team to fit a light fitting above stairs
The guy on the bottom looks like he is thinking about throwing what I assume is the apprentice down those stairs :fearscream: wait what’s that the bottom guy is holding on to :astonished:
i think they did have spurs on them, just got mine handed in 2 months ago thankfully dont have to carry that bloody book around with me anymore
one of the tutors got into trouble for putting a smiley face in the assessor comments section for good entires and sad faces for poor entries
MFS Electrical
Mentor
Scotland, Inverclyde, Greenock
Website
http://mfselectrical.co.uk
If other, please explain
SJIB/SECTT recognised apprenticeship.
SVQ level III electrical installation.
City and guilds 2382 (18th)
City and guilds 2391-52 (I&T)
City and Guilds 2919 (EV Charging)
Business Name
MFS Electrical
Changing a light above a stairwell
MFS Electrical,
MFS Electrical,
