No power to the house, didn't take long to find the problem.
Discuss An interesting callout yesterday.... in the UK Electrical Forum area at ElectriciansForums.net
That was before I touched it.What's been Gnawing at the screw terminals !
(or was that just getting it to undo/unweld ?)
Apart from poor workmanship its high time manufacturers put two screws back onto these sort of terminations. The actual length of conductor that enters these connections is pitiful. You'd only need to fart on one to shift it once tightened.
Meter changes will be an issue on a lot of installations, however in wasn't it the callout fault on this job. The tails come from Consumer Unit into Isco's/Henley blocks. It was down to poor workmanship from the electrician that did the work. The rest of the installation is a mess as wellI have just turned up this reference for a trial done on meter tail terminations by the Electricity Safety Council:
https://www.----------------------------/mediafile/100013801/Meter-Tail-Investigation-Report.pdf
For the busy reader the conclusions, observations and recommendations are on page 10/10.
Reply to An interesting callout yesterday.... in the UK Electrical Forum area at ElectriciansForums.net
