2nd fixing should but oh no..... | Page 3 | on ElectriciansForums
Guest viewing is limited
Discuss 2nd fixing should but oh no..... in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Worcester
Anyone had problems with these slimline fittings,they are so slim,I just can’t get my head round it.
They are not fitting correctly to the wall,looks like these walls need to be flat,not happy with them at all .
[ElectriciansForums.net] 2nd fixing should but oh no.....
I have just finished a job that an electrician walked from that had the same brand. They look so bad. Sure the wall has to be flat and you do need a 35mm backbox, but even with that the finish is awful.
@Midwest in post #20 hit the nail on the head. There is so little movement you can do with these plates. Click Definity is the same.
I fitted out a kitchen with them once, never again. Laser level set the boxes through the lugs as normal, it took a good extra couple of hours to clean out the back boxes more than normal and still a total nightmare to get everything level and straight.
Also agree with @Leesparkykent that they look gash. For the extra money they cost and the extra work to install them I wouldn't have screwless flat plate near me. And standard screwed flat plate is even worse looking...it bends and bows and even on a nice flat wall you can see the silly gasket type thing the manufacturer has behind the plate.
It is. I dunno why @elsparko felt the need to give a dumb. Perhaps you need to get a 2 year old to draw a picture so he can understand it?
2 dumbs and an old --- for tat (basically anything I posted within that last five minutes) as I gave his unrelated picture that nobody remarked on that a dumb these pictures and videos have no relevance and just puts the thread off topic.
I show click deco to customers and they generally all like it. Satin Chrome with black insert. I like how the switch modules are interchangeable and can add dimmer beside a switch in a 3G plate.
Those that don’t like black go for the grey BG Nexus range instead.
Out of all the flat plate stuff I’ve ever fitted, the Home Bargains stuff was by far the best to fit. Still looked like crap imo lol
Reply to 2nd fixing should but oh no..... in the UK Electrical Forum area at ElectriciansForums.net
Typical! If they've used plasterboard screws in a bathroom they'll fail anyway they're not meant for wet areas. So I bet the wrong adhesive was...
    • Winner
I have posted this years ago, it is the way I wire fans which gives the fusing required by a lot of manufacturers and the isolation required...
Recommended Sponsor News
Hi everyone,
cliffed
Worcester
Thread Tags
