type fitted breakers | Page 2 | on ElectriciansForums
Discuss type fitted breakers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
No mate I think he is referring to the statement that came out of the NIC presentation that you shouldn't mix makes of OCPDs in the same board.
And what reg number did they state to back this up?
What about the same "products" with different names on them?
I do understand where the busbars don't line up etc BTW
Sorry, I mean there is a 18th edition updated guidance note 3. To match the new Regs. I can't imagine it says in the new blue Regs book, codes for different mcbs. The Wiring Regs don't do things like that.
When I get mine we must compare notes then sham. What makes you say that sham?
Reply to type fitted breakers in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi everyone, If you are looking for reliable EV chargers, check out our top-rated selection at E2GO! ⚡ Please note that all EV Chargers and...
    • Friendly
I used to dislike Chint domestic circuit breakers, always thought they felt a bit cheap and nasty but that said I never heard of any particular...
Hello freddo (and everyone else who commented!), Thanks for your comment. Using that info, I now have this on the main: and this on the...
