when I did my 17th ,they sat me down pulled out a colouring book and told me to start on that .and when I finished that it was dot to dot book next .
Discuss Stroma 18th edition exam in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
You must have misspelt your name then!85% and yes a proper C&G exam
Are Stroma events letting you take the exam only ?
I've retired from all this malarkey, but I'm thinking of doing the 18th, just to prove I'm not going senile. £140 though.
My local Rexel is putting on a C&G one day course run by the NICEIC for £200 for the course only, £265 for course and BS7671 & £290 for both plus OSG.
Food and drink are provided with a pint afterwards.
So having spent the last three or four days adding quick find tabs to my new 18th edition book and highlighting relevant passages it was taken off me by the Stroma invigilator and I was given a brand new book for my exam!:-(
I was told that Stroma do everything by the book and above board so don't want any accusations of cheating or lowering of standards, think some other schemes may need to take note!
Just make sure you know where the CONTENTS page, that's all you need"Stroma Hi Shane – you may use your own book, as long as it doesn’t have any loose paper with notes in it. However, you can tab the chapters with post-it notes and highlight text. I hope this helps."
Looks like tabs may be okay after all
There were a couple of people that came in the afternoon, just for the exam when I did my 18th with Stroma.Are Stroma events letting you take the exam only ?
I think Stroma have done this to prove a point as other schemes and sparkys regard Stroma as a second rate cheap scheme.......and i am very pleased to be a Stroma memberSo having spent the last three or four days adding quick find tabs to my new 18th edition book and highlighting relevant passages it was taken off me by the Stroma invigilator and I was given a brand new book for my exam!:-(
Reply to Stroma 18th edition exam in the Certification NICEIC, NAPIT, Stroma, BECSA Forum area at ElectriciansForums.net
