Insulation properties of heat shrink, and tape | on ElectriciansForums
Guest viewing is limited
Discuss Insulation properties of heat shrink, and tape in the UK Electrical Forum area at ElectriciansForums.net
SW. London
Have question thats been on my mind for a while. Does anyone know if; at 250 -500 v, a single layer of heat shrink, or a single layer of insulation tape for that matter, covering a bare conductor, sufficient insulation against ?? direct contact/a shock ?
It seems a bit thin in comparison to to the outer sheathing of singles/flex. I could conduct a test with IR test but thought to ask the forum. Obviously a single layer of insulating tape is not the norm but this is in the name of science so go easy.
You could have a point Mate, never gave it much thought before, perhaps I should have, good point though, would have thought the suppliers of the heat shrink would have taken that issue into account, but you never know, await answers with a degree of anticipation.
Like so many things it will come down to checking with the manufacturer. A good quality heatshrink which has been designed and tested as electrical insulation will be good for the job, whereas basic thin heatshrink may only be good for marking or bundling cables together.
If you look on YouTube you’ll find various instruction videos of how to install various cable joints using heatshrink and/or tape. These will give you an idea of the types of insulation materials used and how much is applied for different voltages.
Tape is often used just to cover rough edges or build up layers to give the heatshrink a smooth surface to be applied to.
I always used two layers of heat shrink, I thought this was the standard way of doing it, but I suppose we all do different things
Yeah I suppose its down to sourcing quality and reading specs ect, although insulation tape is called insulation tape.
This is 2 bits of 2.5mm one single wrapped with insulation tape then taped together tested at 250 / 500 and 1000v >999mohms
same with heat shrink :)
[ElectriciansForums.net] Insulation properties of heat shrink, and tape
Hi - it's an interesting question. Extending from @davesparks thoughts in post #3, we need good quality materials, as there may be a difference between what works when you test it and what's good for "10 year performance in a pollution degree 3 environment".
The results of a standard insulation resistance test aren’t really good enough to judge this by.
If the thickness of a single layer of tape was acceptable insulation then cable manufacturers wouldn’t make insulation as thick as it is.
You could wrap a conductor in a single layer of cling film and probably pass an IR test, but that sure as hell isnt acceptable as an insulating layer.
Always worries me when I'm in the pound shop and I see 8 roles of insulating tape for a quid. Obviously will never have been near any testing to prove its effectiveness.
Reply to Insulation properties of heat shrink, and tape in the UK Electrical Forum area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
SW. London
