Cables and cavity walls | Page 3 | on ElectriciansForums
Discuss Cables and cavity walls in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As for Reg No., no, I don't know. But correct me if I'm wrong, has not installing cable within external cavities been banned for years?
There’s no prohibition in BS7671 against running cables in cavities.
In fact BS8436 cable is designed for use in building voids and BS7671 lists installation methods 40 to 44 as being writhing building voids.
[ElectriciansForums.net] Cables  and  cavity  walls
Isn't the cavity a building void?
Even if it is, it's governed by building regs/good practice which preclude bridging the gap.
Everyone knows its bad to bridge the gap, so that water can transfer from the outside wall to the inside wall but it is possible to put a cable in without doing so.
Interesting, I wouldn't class an external cavity wall as a void myself. Cables can not be supported in cavity walls. Insulation also cavities.
OK, do electricians still install cables within cavity walls?
I also thought that even PVC/PVC tails between the OMB and consumer unit could not be installed in the cavity. Contractors in my area would use metal sheathing to cover the tails before plastering.
As I have stated in my post #15, the OSG suggests a max length of 5 meters between vertical cables. The BBB doesn't give any actual length.
Is it good practice? That may be down to the electrician.
If doing so then they would have to take any insulation,if installed, into account and size the cable accordingly.
if the cable entry hole in the outer skin is properly sealed how can water penetrate into the cavity?
Bricks are not waterproof mate.
This thread reminds me, my son is an apprentice plumber on new builds. He asked me what are the regulations for cables in cavity walls?. He asked because the guy he is working with core drilled through the wall for the sink waste in the kitchen he also went through the tails to the cu. (Twice).
When I queried him it turns out if you can imagine looking at the front of the outside of the kitchen, the meter box and cut out are on the left of the kitchen window the tails go into the cavity turns right goes horizontally in the cavity under the window then goes into an internal stud wall and vertically up to the cu. If whoever installed the mains had put it to the right of the window he would not have gone through the tails.
Cavity wall insulation is not a good thing, imho. Anything that bridges the gap is likely to add to internal damp problems. If the insulation is porous it soaks up water, if it isn't, it can transfer water from the external leaf to the internal leaf. If you have a sealed external leaf, maybe it's ok, but that's uncommon. So many folks have been tricked into CWI by government initiatives where unscrupulouds traders persuade folk, especially the elderly, to let them drill holes in their walls...
I have a flat which was just fine and dandy until the CWI was installed, and the damp and mould were almost instant, albeit it was a very cold and wet winter...
The roof was also a problem, but the water ingress from there simply hit the CWI and travelled into the inner leaf.
Crap! I just had an EPC done on my house which said CWI would cost £500 and save me £27/year over 3 years, and if I installed PV panels at about £8k I could save £327/annum...those are govt figures, as the EPC guy simply downloads them...so, would I spend £8k for that saving? No...I'd turn off some lights.
Found from an old IET thread
"Guidance from the Electricity Safety Council says "installing such cables in this way (external cavity walls) is generally an undesirable practice"
The reasons give are
1. Obstructions in a cavity wall, such create a risk of unseen damage during installation.
2. Long unsupported vertical drops may place undue strain on the conductors, leading to damage
3. Polystyrene used for insulation, if it come into contact with thermoplastic (pvc) cable sheathing, plasticiser can migrate from the thermoplastic to the polystyrene
4. Thermal insulation in the cavity may cause cable not to be able to carry the load current without overheating due to their current-carrying capacity being reduced
5. Presence of flora and fauna - unforeseen external influences
There is also a requirement in the Building Regulations 2000, Approved Document C, 2004 Edition, Section 5: Walls, paragraph 5.13 b
and NHBC Standards state that no cables other than electricity meter tails are to be located in the cavity of an external wall"
I doubt if you could find a BS7671 reg or Building Reg against it. But if its at all possible, a cavity is not the place for any cable, unless its straight through or less than a couple of meters, aka meter tails etc.
The house I'am doing up has cables running up and down in the cavity.
Would this be just above the consumer unit (fuse board)?
No the consumer unit is on the same wall about three yards in the opposite direction. There's a double socket in the kitchen, below where the cables disappeared into the cavity. The cookers further along on the same wall.
It could be the way the cables have been routed into your CU, i.e. via the cavity. There's probably thousands of properties wired in this way in the past. As others have said, not against any regs etc, just not good practise in my & others opinion. But I suspect its been like this for some time, to no avail. You would need to employ a competent electrician and seek he/she's opinion.
Before we bought the house we had the wiring surveyed by an electrician and he couldn't find any major problems.
Reply to Cables and cavity walls in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I think it's more a case of why you would hide a cable in somewhere that is intended to be a clear gap.
Is the property suitable for ASHP? There are quite a few unscrupulous salesmen promising all sorts, but without the insulation factors and large...
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Better off with the click prw213 as it has twin screw termination.
